0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | Do any of you have a drawing with measurements for the headliner of a 1950 Chevy truck? I would like to make my own. My email address is [email protected].
1950 4400
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | When I made my own ABS headliner for my Suburban, I used construction paper to make a pattern. Then transferred it to the ABS. Paper and masking tape could be your friend. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Joe Alan You could buy a cheaper damaged one from carter, then use it later,or if just half of your old one is there copy it. Hard to make the pattern . Make my own out of cardboard then adjust it on the next one !! | | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | Thanks for the help, sometimes I think I couldn’t make without the help on this forum.
1950 4400
| | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | I’ll give Jim Carter a call and see what he’s got. Thanks
1950 4400
| | | | | Joined: Mar 2014 Posts: 4,478 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,478 | I have an original one removed from a 1951, but there are 2 problems: it doesn't lie flat after all those years and two...it has shrunk over time. So you'd have to make yours larger and then trim it to fit.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
