4 members (TUTS 59, 55shaker, Wrenchman, Oswald), 55 guests, and 1 robot.
Topics128,089
Posts1,056,010
Members48,430
#1400729 03/09/2021 10:19 PM
Can anyone tell me what size screws were used to attach the defrost ducts under the dash? I am assuming the screws go in from underneath?
Thank you.
1949 chevy 3100
Scotts IFS
4-link rear
L-31 5.7l vortec
I'm going to guess they're #8 round head sheet metal screws. Yes, they do go in from underneath. The defrost nozzles (I refer to the hoses as ducts) have a slot on one end, so you can start one screw, fit the nozzle, then install the other screw. Probably 1/2" or less in length. It's been a long time since I took mine apart, so going from memory.
Klhansen, Thank you for that info. I will get some #8 and try them out.
Love this forum. So many helpful owners on here.
1949 chevy 3100
Scotts IFS
4-link rear
L-31 5.7l vortec
I put mine in my '53 from the top, worked Ok and probably a lot easier.
Wondering how that worked, unless you used oversize screws that engaged the notches in the nozzles. Or maybe the '53s are different. The head of the screw on the bottom holds the nozzle in position.
Here's one of Brad Allen's pics showing the nozzle with a clip on one end and notch on the other.
Defrost nozzles
On my '51, you slide the nozzle up under the dash where you have a clip on the nozzle slip over the hole. The other side is pushed up against the dash where there is a small hole next to the nozzle slot that you drive a screw, from the top, in to the body nut attached to the nozzle.
Here is how the factory did it, these are instructions from a NOS Heater, 1953.
https://www.flickr.com/photos/advance-design_parts_co/32351687978/in/album-72157631872034068/
Brad to the rescue. grin
Moderated by  ndkid275, Phak1
