0 members (),
182
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 5 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 5 | I am going to have my seat reupholstered and while the seat and back are out I am going to install lap belts. I checked on Amazon and eBay and there are many lengths and brands, some just for golf carts. Can anyone tell me what worked for you, length and brand? My truck is a 51 Chevy 3600 and I am a thin guy. I would hate to buy the wrong size and have to send them back. | | | | | Joined: Sep 2010 Posts: 2,310 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,310 | I used the rear seatbelts off of a chev caprice around 1988-90 fit good ,the centre belt is not retractable but adjusts and the passenger and drivers side retract . | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | There is a really good write up on here with tons of pics. I used the same belts as the guy in the write up and i am very happy with them. These trucks are kinda tricky to mount belts in with the stock seat frame. I couldn’t find the exact original write up but if you look at the 6th post down thats the one I’m talking about. They say “giggs” wrote it up. Good pics and process. Lap belt
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | I used 3 of these in my 1950 3100. https://www.ebay.com/itm/254274282919They worked Great! I cut & drilled plates for inside and under for the bolts. Todd
1950 Chevy 3100
| | | | | Joined: Feb 2019 Posts: 4,480 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,480 | I installed 2 three point and 1 center belt. I also got mine from seatbelts plus. There a bit more but they are made in the USA. Here’s a link to my post on how I did it. [LINK]
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Seat belts are not hard. I did the same as Phak. Just make sure that you have something backing up the bolt so the nut/bolt can’t pull through in an accident.
Chris | | |
