0 members (), 100 guests, and 2 robots.
Topics128,157
Posts1,056,875
Members48,456
Just put all new drums, shoes, cylinders and hoses on my '69 C10, no power brakes.
When you press the brake pedal it vibrates badly, seems to be a higher frequency than what I've experienced with warped rotors. Is there some other possible cause or is it simply warped drums (out of round)? Doesn't do it when using the parking brake so presume it must be the front, can't tell if it's both or just one, doesn't seem to pull to one side or the other.
New drums from the Irish chain, obviously expected them to be perfectly smooth. Any help appreciated.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
It sounds very much like what you described to be an out of round drum. If you have an auto parts store locally that can turn drums have them set them up and check the runout. Generally if it is that far out even turning it probably wouldn't work. Plus it shouldn't be necessary to turn a new drum. Since it's new, the supplier should replace it.
Fred
Riding in the Passing Lane
You may not have a drum seated on the hub good. If the old ones were hold on with rivets and you knocked the heads off the rivets they might not letting the new drum seat good.
George
1972 Chevy c10 Cheyenne Super
B Online: Content
George
X2, have seen that.
BC
1960 C60 pasture art
Could it be a loose rim on the hub...are all of the lug nuts tight?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Having the new replacement drums checked for runout tomorrow morning, and then swapped with the shaker versions on Friday. Will report with findings then.
I'm thinking an installation issue as, while not impossible, warped new drums seems unlikely. Thanks for the feedback.
Did you spray down the drums with Brake Cleaner before installing them? Just wondering if they were coated like rotors and now your shoes are grabbing?
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
quote=Wrenchbender Ret.]You may not have a drum seated on the hub good. If the old ones were hold on with rivets and you knocked the heads off the rivets they might not letting the new drum seat good.
George[/quote]
Winner winner chicken dinner.
They're looking for drums with the integral hub, not so much of a seating issue as a concentric issue.
