1 members (Russ_B_10), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
#1400585 03/08/2021 9:09 PM
I bought a condition unknown 235 at a flea market. A visual tells me it was probably rebuilt at one time and the top end was pretty clean. i have mounted it on a temporary stand and have soaked cylinders with marvel mystery oil. I have also lubricated valve stems and tappets. I have been able to rotate the crankshaft using a prybar against the dowells on the rear crankshaft flange. However, I continually hit a sticky spot at the same spot on the 360 degree revolution.I have continued to soak it and rotate the crank through the sticky spot. I have thought of bolting on a flywheel, bellhousing and starter that I have and seeing if it will start . The sticky spot worries me but I don't want to invest money in new parts or a ring job . I was hoping for a driver motor that had a few miles left on it My gut feeling tells me to invest in at least a gasket set. Any advice on working out the sticky spot will be appreciated.
Geo55 #1400588 03/08/2021 10:01 PM
Read and re-read the Tech Tip here on Stovebolt about resurrecting a long dormant engine. Then proceed at your own risk.
Geo55 #1400590 03/08/2021 10:33 PM
GEO 55 The local body shop got a car stuck so tight they took out the tranny and clutch bolted on an 8 ft. lever and finally broke it loose. A few days later I was in there ,he said try it...ran like a sewing machine ! Lube-up your valve stems and try it !!! Might have a mud dobber nest at that tight place !
