1 members (Youngin' Tut 59), 123 guests, and 3 robots.
Topics128,201
Posts1,057,276
Members48,466
I know I want the clear lens. I also want the one wired for turn signal as well as parking light. Where do you guys recommend I buy from? There are some on Amazon, but their feedback says the bulbs don't seat well in them. There are ones at Brothers, but they appear to be designed for OEM an use incandescent bulbs.
Anyone already been down this path who can help?
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
https://www.ebay.com/itm/Pair-N-O-S-GM-55-56-57-Chevy-Truck-Parking-Light-Assemblies/154315246610?
This is a nice OEM. pair If you want original. If not what are you wanting to accomplish with lights.
!956 Gmc Napco 4x4 Factory line built .
Thanks, sack.
I'm not restoring my truck to original, so I was all set to order the repops that take the 1157 bulb and have turn signal wiring built in. But then, I started to notice some of those are getting negative feedback for not holding the bulbs well. I definitely don't want to be in that situation.
