2 members (RLB, 51 3804),
126
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | I'm considering them for my '57 panel and wanted to see pics and hear feedback.
These look interesting:
https://www.ebay.com/itm/LED-Headlights-DRL-Light-H4-H13-7-Inch-for-1947-1957-Chevrolet-Truck-GMC-Pickup/383984748026?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3D23cf6c4ed08846ec804b97b5bdab75e1%26pid%3D101224%26rk%3D1%26rkt%3D5%26mehot%3Dnone%26sd%3D142734612026%26itm%3D383984748026%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganic&_trksid=p2047675.c101224.m-1 | | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 | I ordered LED headlights a couple of days ago. Not like the ones in your link. The ones I bought were plain 7" headlamps designed for H4 halogen bulbs; bulbs need to be ordered separately. I also bought LED bulbs designed to replace H4 halogen bulbs. The bulbs are only 26 watts, so they draw less current than the old sealed beams. (no relays required) I'm sceptical that they headlights will fit, but this review on amazon was encouraging: Hi there The glass profile is flater. Other than that it fits my 50 chevy pick up perfect. I installed a set of LED bulbs and the difference is night and day to the old bulbs I had no issues with my headlight bezel or inner ring Hope that helps you. By Evan S. on January 6, 2020
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | Flater?  | | | | | Joined: Dec 2019 Posts: 451 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 451 | professor redline. as a quote misspell use (sic) to pass the blame! LOL
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 | I'm sure it's a typo and he meant flatter. i.e. The curvature of the front of the replacement headlights is less than the curvature of the old sealed beams. Hella replacement headlamps are like that.
Evan may be a member here. If you are reading this, thanks for the review.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | I was totally kidding, thus my smiley face.
I knew what they were trying to say. | | |
