11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible), 116 guests, and 1 robot.
Topics128,124
Posts1,056,347
Members48,441
#1399893 03/03/2021 10:42 PM
Riding in the Passing Lane
Can a fellow bolter tell were to get the spacer ring to put a Sagina 4 speed in a bell housing for a sm465?
George
1972 Chevy c10 Cheyenne Super
Got some dimensions- - - -OD of the Saginaw bearing retainer, and the ID of the bell housing bore? I can make one as soon as a part for my lathe arrives. It's out of commission right now.
ASU Offline
if you are talking about a ring to space a 4.686 transmission into a bell housing with a 5.125 hole, Advance Adapters sells them. $30 on Summit's website.
https://www.summitracing.com/parts/...-DRtcrXFrPkzBX-0ahP8BNmx2CIaAgZDEALw_wcB
Jon
I'd suggest drilling and tapping that ring for a couple of short cone-point set screws to secure it to either the bell housing or the bearing retainer. If it slips out and gets wedged between the throwout fork and the bell housing, things could get "interesting" in a hurry!
I used advanced adapters or novak-adapt. It fits tight so dont worry about it moving.
