1 members (TexasA&M48Truck), 190 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#139988 03/03/2005 6:55 PM
Help! Now that my 1.5 Ton will go 65mph, I need to STOP the thing.
My 46 did not come with a brake booster.
Can I get one from NAPA? see link:
http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_kw.d2w/report?CATALOG=&org_string=brake%20booster&search_string=Power%20Brake%20Booster%20-%20H/D%2 0Truck&MAKE_ID=&MODEL_ID=&YEAR_ID=&ENG_ID=&ENG_VIN_ID=&SUBMODEL_ID=&BODY_STYLE_ID=&TRANSMISSION_ID=&BRAKE_SYSTEM_ID=&DRIVE_TRAIN_ID=&ENG_ASP_ID=&ENG_FUEL_DELIV_ID=&ENG_FUEL_ID=&STE ERING_ID=&SUSPENSION_ID=&lookup=NONAPP&sort_flag=&START=1
. . . uh . . . dang, you might want to copy and paste this one.
Anyway, there are SEVERAL choices with the "4th Series" under H/D, (heavy duty??)
Seems most are for the line size for the 'plumbing'.
Can I put one of these on my truck? Even though it did not originally come with one? Any inherent problems with this? etc.
Which one should I start with??? frown
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
#139989 03/03/2005 11:19 PM
Y
Y Offline
Tim, Check your E-Mail............
#139990 03/04/2005 12:08 AM
Tony - Got it.
Try: http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/homepage.d2w/report
and then: top left corner, under CHANGE VEHICLE put 46 and Chevrolet Truck and any 216 engine.
Then you will see the choices.
And I am interested. Just leaving work and posting real quick until I get home.
#139991 03/04/2005 12:10 AM
Dang! I always forget something.
Under KEYWORD put: Brake Booster
#139992 03/04/2005 6:02 PM
Tony -
The 11" Diameter will not work. I measured this morning and even though it is going under the truck on the frame rail, there is not enough room without moving the exhaust and bracket.
I need an 8" Diameter Booster, perhaps.
Thanks anyway - Timmer
