6 members (32Fordpuchoptop, TUTS 59, Wayne67vert, Oswald, Otto Skorzeny, baldeagle), 74 guests, and 5 robots.
Topics128,021
Posts1,055,348
Members48,420
#1399644 03/02/2021 2:53 AM
I finished my alternator bracket except for the right bolts. The damper that is in the pictures is a slip fit mock up damper. This is the SFI damper that BHJ made me that I clearanced the bracket for. The alternator is about 1 1/2" further forward than stock. It is very strong. I came out pretty good for a guy just winging it. Thank you for your time.
Fox Offline
I wish I could wing it like that!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1399676 03/02/2021 6:34 AM
Thanks. Here is a better picture of how it works. I don't know what those holes in the block are for but they sure are handy. I will probably use the ones in the same place on the other side to mount the oil pump. That is a Mechman custom built alternator and the round part where the bolt goes through was amazingly round and consistent so I bored the hole a few thousand's bigger and it is really rigid side to side even without being tightened down.
mick53 #1399688 03/02/2021 12:30 PM
AD Addict & Tinkerer
Nice job. I’ve been following you thread. Your building quite an engine there.
Phil
Project Journals
Stovebolt Gallery Forum
Crusing in the Passing Lane
Those holes a engine mount bolts for front cross mount with rubber pads on each end.
Ed
Mick, if you don’t post a long video of that monster running when you get it going, ALL of us are coming to your house for a live demo. BTW, you’re footing the fuel, food and lodging for all 41,000 of us!
nanner
I'm starting to feel a little less than adequate on the alternator bracket I just made!
Sir Searchalot
Sir Searchalot
It'll do, I guess.
nanner
My door is always open. When I get it done maybe we could meet at a vintage drag event and I'll let you drive it if you want to. I will be able to tailor the power output to the track with these strange things called a clutch and gas pedal. I want to be fully involved in the driving process. I know I could save a couple of tenths with an automatic and a two step but that's just not for me. To each their own.
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I'll bring a lawn chair and cooler just say when!!!
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Originally Posted by bartamos
It'll do, I guess.
grin thumbs_up
Originally Posted by MNSmith
[quote=bartamos]It'll do, I guess.
The simpler the better. Nice job. A little polishing would help the aerodynamics on a molecular level.
I'm kinda going the anti-polish route. Less work in the long run. Sticking with the "blast it and clear it" approach.
MNSmith Did you plaz that?? Looks good-I never could do blue-prints and make patterns like that !!
Plaz? Quick story is, I thought I found a bracket for a Denso alternator for my V6. It is going in a Model A so I didn't want it up high (blower) or hanging wide out the side. Drivers side engine had no bolt bosses for a bracket, just the passenger side. The bracket kit that showed up wasn't close at all. So, I could use part of their bracket but have to make my own stand-offs. I decided I could tuck the alternator up much higher and closer to the engine than their bracket allowed for. So I traced their bracket, dropped the mount holes by 1", making a shorter bracket. Traced it to some 1/2" aluminum plate. Cut most of it on a band saw, cleaned it up and made the slotted holes on a mill.
