| | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 4 New Guy | | New Guy Joined: Feb 2021 Posts: 4 | Has anyone installed seat belts in a 41-46 Chevy 1/2 ton? If so was it fairly straight forward? If not what were the complications and how did you solve the problem? I know a lot of questions, but any information would be appreciated. | | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | I put both 3 point harnesses and a 2 point harness in a 51. It was straight forward! What kind of belts are you using?
Chris | | | | | Joined: Feb 2021 Posts: 4 New Guy | | New Guy Joined: Feb 2021 Posts: 4 | Chris I'm thinking about installing standard seat belts. I have not picked an option yet. Any recommendations? | | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | 2001 Silverado seats with integrated 3-point belts. I didn't want to mount anything on the pillars so these worked great! Nothing in the center.
Mason
1947 Chevy 3100 -57 Chevy 235 -95 S10 T5 Transmission -97 Blazer 3.42 Rear End
| | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | I can’t remember the brand that I used. Which ever, ensure you put a plate on the opposite side of the floor or pillar so the bolt doesn’t pull through.
Everything is up to you. I used 3 point to keep from slamming my face into a metal dash. I also needed them so kids could ride with me.
Chris
| | | | | Joined: Sep 2018 Posts: 42 'Bolter | | 'Bolter Joined: Sep 2018 Posts: 42 | Gents, I have a '40 Pickup which I'd like to fit seat belts to, but mine has an Australian cabin-they were the same from '39-46. The fuel tank is under the seat which may make it a bit more difficult. Also, I would like to fit some sort of grab handle/strap above the passenger window for my wife to hang onto as she gets nervous without something to hang on to. Has anyone done anything like this? Many thanks, Bob | | |
