| | | Forums66 Topics128,277 Posts1,058,441 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 64 | Hopefully just a quick question. The passenger side inner fender panel on my 41 has an L shaped lip that sits just above the frame rail. The driver side has no similar lip, and was screwed to the side of the frame rail. Is this correct? Thanks in advance for your help.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
1941 AL 3/4 ton 125-1/4 WB, bought by my Great Uncle Matt in 1942. Still in the family.
| | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | No. Attachment is the same for both sides, as found on the passenger side. At least that was how it was/is on my trucks. I imagined securing that panel to the frame would eventually result in it tearing since it wouldn’t be able to flex as needed with normal body movements on uneven road surfaces. | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Agree. Attaching to the frame will stress these more than than the thin gauge metal could handle. They should have some flex as the frame will flex, along with the cab and front radiator that will flex independently too. I notice stress cracks at the attaching points - having seen and repaired a few over the years. | | |
