2 members (elhippie64, baldeagle), 56 guests, and 12 robots.
Topics128,020
Posts1,055,345
Members48,420
#1399102 02/27/2021 1:33 PM
Folks,
1950 chev, 216 with 3 spd manual, enclosed tube and diff
Whenever shifting down from 3rd to 2nd, no matter how much i try to ease the gears in, they always give a little graunch, is this a common thing or is it possibly a sign my box is not the best
Steve
Steve,
I'm only speaking for my 1950 3100 3 speed. Mine does it every time. Sometimes just a little but it's always done it. New fluid, level checked, ect.
Good luck Hopefully the Experts will be along..
Todd
1950 Chevy 3100
What kind of lubricant are you using? The modern synthetic lubes are too slippery- - - -the brass synchronizer blocker ring can't get enough traction on the 2nd. gear to slow down the counter gear and prevent clashing. Drain the transmission, flush it by filling with a a solvent such as Mineral Spirits or Diesel fuel and idling the engine with the transmission in neutral, drain and refill with 90 weight mineral oil- - - -not multi-grade synthetic lube. If the gears still clash, you've got a worn out synchronizer.
Jerry, that is an awesome response, very very informative
Steve
New international word of the day. "Graunch."
I like it. I only hope that I will remember it in case I ever make it to Australia. Its on my bucket list.
