2 members (Guitplayer, MickeyP),
70
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 86 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 86 | Folks,
1950 chev, 216 with 3 spd manual, enclosed tube and diff
Whenever shifting down from 3rd to 2nd, no matter how much i try to ease the gears in, they always give a little graunch, is this a common thing or is it possibly a sign my box is not the best
Steve | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Steve, I'm only speaking for my 1950 3100 3 speed. Mine does it every time. Sometimes just a little but it's always done it. New fluid, level checked, ect. Good luck Hopefully the Experts will be along.. Todd
1950 Chevy 3100
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | What kind of lubricant are you using? The modern synthetic lubes are too slippery- - - -the brass synchronizer blocker ring can't get enough traction on the 2nd. gear to slow down the counter gear and prevent clashing. Drain the transmission, flush it by filling with a a solvent such as Mineral Spirits or Diesel fuel and idling the engine with the transmission in neutral, drain and refill with 90 weight mineral oil- - - -not multi-grade synthetic lube. If the gears still clash, you've got a worn out synchronizer. Jerry
| | | | | Joined: Feb 2021 Posts: 86 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 86 | Jerry, that is an awesome response, very very informative
Steve | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | New international word of the day. "Graunch." I like it. I only hope that I will remember it in case I ever make it to Australia. Its on my bucket list.
