1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1398821 02/25/2021 6:37 PM
I have a 1950 3100 and I am putting in the windlace rubber. I have one side in and in the tight corners it is bunching up. Do you have any ideas to reduce this? It is Winter and cold here, so that could be aggravating the install.
Former BMW Rider
Former BMW Rider
Jerry,
Here's a method that was devised by marzach. I had the same type of problem on my '47 that you've encountered on your '50. I've attached some before and after pictures for your review.
Installing Cab Windlace without Kinks
Here’s a great Tech Tip from Charles Smith (marzach) on how he installed cab windlace without any kinks. To get your cab windlace installed without kinks in the upper rear corner, here is the procedure that worked for Charles.
Begin by cutting a 14 inch section of 3/8 inch nylon rope that has a very tight weave (3/8” is a little larger than the inside diameter of the windlace bulb) and a heavy pull cord a couple feet longer than the total length of the windlace. The pull cord I used was nylon and slightly larger than a pencil lead. Melt one end of the nylon rope and grind down the melted outside edge area to the same diameter as the rope. This will give the rope a little more strength for the following step. Tie a small knot in one end of the pull cord and with air pressure blow it through the full length of the windlace bulb. Attach the other end of the pull cord to the melted end of the rope about 3/8 of an inch from the end. You will have to punch a hole in the rope to attach the pull cord so the pulling motion will not be off center. Measure and mark the windlace area that will be at the upper rear corner (the area which is prone to kink during installation). With a person on each end of the windlace, pull the nylon rope into the section of the windlace bulb that will end up in the prone to kink corner. There will be a slight interference fit when the rope goes into the windlace bulb and will remain in the area you place it. The nylon rope will retain the original shape of the windlace as it goes around the kink prone upper rear corner during the installation process. The pull cord will remain in the windlace with no ill effect, just trim off the ends as needed. You might want to have a pull cord at both ends just in case the primary pull cord comes loose or breaks, so you can pull the rope back out and try the process again. Otherwise, the rope will have to remain where the pull cord comes loose. I applied a little Vaseline to the rope before installation. I used Jim Carters grey windlace and was able to get both sides installed without any kinks. I hope this windlace installation procedure works just as well for you.
Let me know if you have any questions, good luck!
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Moderator, Electrical Bay
You can also use an old-style screen door spring. Just pull it through until you feel the spring in that area of the bend. You'll only need one spring per side. Cut it in half and tie your pull cord to the already formed ends. Hint: you need this at both of the curves. Measure and connect the two spring pieces with cord so that when you pull one through, the other will follow it and be at the right place. Coat it with Ru-Glyde or Armor All...something like that. If your seal pieces are made of rubber or neoprene (including neoprene blends and same-family variants) do not use Vaseline. It will cause these to deteriorate pretty rapidly.
~ Jon
Moderated by  ndkid275, Phak1
