| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13979 01/09/2002 5:26 PM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | Can any of you fine people recommend a paint for my Fenton duals (new)? I would prefer something that comes in an aerosol can because I'm not set up with a compressor and sprayer.
Thanks in advance.
Geoff
Seek results, not perfection. Remember this is a truck, not a Rolex watch.
#13980 01/09/2002 5:28 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Don't use paint use Black Stove Wax It's cheap and don't fall off | | |
#13981 01/09/2002 10:48 PM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | J.H.
Thanks for your advice. I was hoping for a metallic silver though? Any other suggestions?
Geoff
#13982 01/10/2002 12:22 AM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Jim, you use the stove wax on your Stutz too?  I'm told POR-15 sells a good quality header/manifold paint in silver. Haven't bought any myself yet (but likely will). Online at www.por15.com , see for yerself. It's brush-on, not spray-on. However! Prep is more important than anything for high temp parts. Sandblasting is strongly recommended - even fingerprints on the part before painting can cause problems later on. The POR-15 can or literature may have other recommendations. -Boyo [ 01-09-2002: Message edited by: boyoconnor ]
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#13983 01/10/2002 12:52 AM | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | I'm with J.H.P. on this one with the Stove Black Wax, apply once a month, looks great, dirt cheap, I hit my steel toe work boots with it in a pinch.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#13984 01/10/2002 4:30 AM | | Anonymous Unregistered | | Anonymous Unregistered | Black stove wax? Never heard of it. What is it and where can I find it? I have used the POR-15 brush on silver on my Fentons and so far so good. | | |
#13985 01/10/2002 6:34 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can get stove wax at a real hardware store. I used the POR exhaust paint but missed one critical step, there is a time limit for how long you have before getting the manifold hot. I waited too long and have a rusty manifold. When I go with headers, I will probably get them powder coated. Expensive, but tough to beat.
Fred 52 3600 69 C-10
#13986 01/10/2002 3:48 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | D...........
Stutz is powder coated with some expensive stuff that looks like STOVE BLACK WAX.
I lost my can of wax...maybe I lent it to someone.Don't know In So Cal there aren't no Farm and Fleet Phat told me he'd get me a can but that hasn't happened yet.
You comming to Turlock? | | |
#13987 01/10/2002 3:55 PM | | Anonymous Unregistered | | Anonymous Unregistered | I did send it before your trip!! I only sent a tube. You want me to send a can of it?? Its only on the shelf this time of year..
Rutland products(out of rutland VT) and they call it "RUTLAND Stove Polish" now . | | |
#13988 01/11/2002 12:08 AM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Geoff,
I used VHT brand exhaust manifold paint on the cast-iron exhaust manifold of my '72 Chevy 250; it's kind of a stainless steel color.
So far it's holding up ok; you do have to really clean the part first, and thoroughly de-grease (Brake-kleen), and after the part dries to touch, your supposed to bake it at 500-600 degrees for at least an hour to "cure it". (Don't try it in the kitchen, if you're married! No amount of scientific logic will convince the wife!) I "cooked" mine in the gas grill.
This Rutland Stove black has me curious though...
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
