3 members (TUTS 59, Jon G, 1 invisible),
163
0
Mod | | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Hello guys, While I was away touring in my 41 half ton I met a guy who is restoring a 52 big bolt. It has dual rear wheels. He has little info on it. It is an Australian truck and might therefore have Canadian connections. He has been told that it is an 1142 model, DG series.
I think the chassis number is 37607 HA. It looks about a two tonner. He was also wondering if the bonnet emblem on these bigger trucks is the same as the half ton AD trucks. Any help would be really appreciated.
Bob | | | | | Joined: Mar 2005 Posts: 14 Junior Member | | Junior Member Joined: Mar 2005 Posts: 14 | I am in the same boat, is there an easy way to identify the aussie trucks?
Jason.
46 1 1/2ton
| | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Ok folks with the number 37607 HA. I was wondering if any of the Canadian members knew if Chev had an assembly plant in Halifax. just guessing that that may explain the HA.
Bob | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Hi Guys!
Here's a Canadian view.
From my decipher page it goes like this for the older models.
e.g. Vin #6954300440---The 6 is for 1946--95 indicates GMC 2 ton--43 means cab and chassis--00440 indicates vehicle number.
I don't recall that GM had a Halifax plant although there was one in Regina along with the main plant in Oshawa. Although VIN's are different nowadays I think in /52 they were still as I described.
It's possible that vehicles built for export were given different style ID's so you could write to GM Canada Vintage Vehicle dept.--1908 Colonel Sam Drive, Oshawa, Ontario L1H 8P7.
Good luck with the search. George | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | George,
Thanks for the help mate. I'll get in touch with GM in Ontario.
All the best
Bob | | | | | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | Jarge,
You fellers in Canada are an amazing lot. All the good information and contacts for anyone, anywhere around the globe. Thanks, aye!
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
