1 members (mick53),
202
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | I'm sure there is a write up on this somewhere that may have the answer to my question but I haven't been abke to find it. ..Sooo here is my current situation while I wait for parts to show up. I am working on getting my recently aquired 1953 chevy 3/4 ton with original 216 ci and 4 spd manual trans back on the road after its roughly 30-40 year slumber. I have been removing and inspecting various parts to give this beast it's best chances and have found that the radiator fan has a bent fin on one tip and a crack halfway through the fin near the axis. My fan measures 18" from tip to tip. The problem I am having here is where to get a replacement 18" fan, or should I just replace it with the 15.5 fan that basically all of the classic truck parts suppliers say is what I should be using? Carter has a write up on fan blades and even some pictures of the blade I am looking for but no 18" fan for sale. According to the write up the 18" was an option with a radiator with aditional cores. Sorry for no pictures, My phone doesn't do pictures so well.
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | If it were mine I would use the 15.5" as a test and to make the truck drivable, then you could do some more research on the original and maybe come up with a plan to repair it.
| | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | You could always post in the “Truck Parts Wanted” forum.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | I got a 15 if you decide togo that route. Pm me if so. | | | | | Joined: May 2005 Posts: 86 'Bolter | | 'Bolter Joined: May 2005 Posts: 86 | I bought a new old stock 18" fan blade on EBay a couple months ago. Even had the original box. It was $80 dollars but I knew it was not abused. If you get a used one you might want to clean the blades with a wire wheel to bare metal where blades meet the hub near the edges and inspect for small cracks. (Just for piece of mind) I know that 2 blade Model A fan blades were prone to fatigue cracks near the hub.
Mike 1951 Chevy 1/2 ton w/ 1959 235 1971 Chevelle
| | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I had one of those nylon fans on my 55 Chevy. They do move a lot of air.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The amount of air move is proportionate to the diameter of the blades, squared. A larger fan can be run at lower speed by changing pulley sizes to save gas, reduce noise etc. The opposite (a small fan turning faster) uses engine power at a higher rate for the same air volume: the fan RPM, cubed. | | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | So good news.....maybe, I have found an old classic car yard near me sp I woll be headed out there yo hopefully find a fan that will either get me by of just solve my problem all together. O'll let you guys know what I find....or don't find. I will be looking for something to keep the stock appearance so a metal fan for sure. | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | When my '53 1/2 ton had the original 216, it had the large 4-blade 18" fan attached, and never ran hot except idling at a stoplight in 105 degree Mississippi summer heat. Swapped to a rebuilt 261 with 4-blade 15" fan. No problems whatsoever.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Dec 2020 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 103 | I found an 18" fan on ebay identical to my original so I'm good not Thank you all for your input. | | |
