8 members (Hush, Lightholder's Dad, John L., Otto Skorzeny, lumbersawyer, FAST55, Hanks custodian, KEVINSKI),
162
Mod | | | Forums66 Topics128,075 Posts1,056,007 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | I have a problem on my 235 that I need some opinions on. My engine has hydraulic lifters and if I pre load them the engine will miss on #5 cylinder at idle. I have narrowed it down to the exhaust valve. If I run that lifter loose to the point it ticks, the miss will not be there and it runs perfect. I have run a compression test and have 130 psi on all cylinders. I have pulled the lifters, dis assembled,cleaned, reassembled and soaked in oil. I set the preload with the engine running by loosening the valves until they tick then tighten until quiet. Thoughts on this? | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The plunger is sticking in the bore, and won't accept a preload. Remove that lifter and give the piston a mirror polish on a felt buffing wheel with jeweler's rouge. Do the same thing to the bore of the outer part with a gun cleaning wool mop and rouge, chucked into a drill motor. The plunger should slide freely in and out of the lifter when the lifter cleaned of all oil with a solvent such as brake cleaner, without sticking.
BTW, your adjustment procedure is incorrect, according to the service manual. It's virtually impossible to get the correct preload on a lifter with the engine running. Jerry
| | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | Jerry thanks for the advice. i will pull that lifter and polish like you said. I tried setting the preload like the manual I found said and all the valves were held open giving zero compression to start the engine. There are so many ways to preload on the old interweb it is a bit overwhelming. With these being aftermarket lifters, from a previous engine builder i have no clue what the proper preload is. | | | | | Joined: Feb 2019 Posts: 4,479 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,479 | When you “pre-load” the lifter cold, some of the lifters may not be pumped up and will feel the plunger spring before you get any real resistance. I spin the push rod until it takes out any play and I feel a slight resistance, then turn it down the specified amount. I prefer 3/4’s of a turn but others have their preferences.
Edit: You need to just feel the plunger spring without compressing it, and that will be your zero lash starting point. Thanks Pre ‘68 Dave for pointing out my unclear instruction.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A week valve spring can cause the same problem. The extra pressure from the spring you compress in the lifter when it is set, can over power the valve spring, holding the valve open.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2021 Posts: 1 Moderated | | Moderated Joined: Sep 2021 Posts: 1 | Kinda have the same problem hope someone can help I’m new to the forum I have a 69 c10 with the 250 4.1 L6 we just rebuilt it and upon first start we found number 2 cylinder had a miss and virtually no compression. Took the head off found a crack. I purchased a rebuilt head from tom at 12Bolt.com upon first start we found the identical problem a miss in number 2 and virtually no compression (my guy says he got 30lbs) is this a coincidence or is there something I missed…I need help ….please any suggestions are welcomed Pacman | | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | Turned out to be a bad seat on #5 exhaust valve. Head has been rebuilt. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Pacman Learned that if that version of 6 gets hot it can crack between the lifter bores along with the head,saw it on a 292 combine engine in about 1971. | | |
