9 members (Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 52Carl, dt235sd, BC59, 2 invisible), 153 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#1397920 02/19/2021 12:10 PM
PA OUTLAW
PA OUTLAW
Hello all 1954 chevy 3100 . My question is on the parking Brake .Each side on the parking brake cables in front of rear tire there is a clevis that threads on to the brake cable Question is are those clevis different length > I am a little short again .THANK YOU IN ADVANCE!!!!!!!!
AD Addict & Tinkerer
Yes, I had a similar experience with my ‘52. One side was shorter than the other. The original is longer than the replacements that are available from the vendors. I did however get my short/long combination to temporarily work by adjusting the rod that goes up front. I have since got an original replacement.
My suggestion to you is to post in the “Truck “Parts Wanted” forum as that is how I got my original clevis.
Phil
Project Journals
Stovebolt Gallery Forum
My spare is already gone or I could fix you up with one.
