7 members (JW51 , TUTS 59 , 3800GUY , Otto Skorzeny , cmayna , 52GMC35424JD , 1 invisible),
105
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,065
Posts1,055,863
Members48,428
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
They go between the radiator support and the lower radiator baffle.
One is shorter do you know what side it goes on?
Crusing in the Passing Lane
See how they fit in the factory holes, they should be readily available, perhaps someone will post a picture. Do you have any manuals? Ed
Moderator
Moderator
I had those braces left over, thought they were for something else. I left them on the shelf for 10 years.
Here's a picture.
1950 Chevy 3100
Not shown on Shaffer's pic, but the center vertical support goes where I circled in red. The support rods connect near the top of that and extend down to the apron to holes I can't see in this is pic. Notice the center vertical support is offset to the driver's side, so the shorter rod would go on the driver's side.
1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car)
