5 members (5 Window 9434, Jon G, John Dlugos, jmoore, moparguy), 96 guests, and 4 robots.
Topics128,120
Posts1,056,325
Members48,439
#139788 07/10/2004 3:50 PM
I am purchasing a 1942 Truck that was used as a grain hauler. I already posted in the VCCA chat with some interesting issues. According to this VB code that means the truck is a 1939. However, this truck is a 1942 according to the Title and Registration papers. The truck is a 1.5 Ton. So far it looks like the block is a 235 and not a 216. Any help is appreciated. Thr truck is in rough shape also. Lots of rust with a froze engine. Any ideas on the value?
VIN# VB 56S130852
Block# 839931
Mill Pad# BM732344
Chassis# 8M543
Here is a picture from your archives which looks just like it. Although I believe this is a 2 Ton truck.
[img]http://www.stovebolt.com/images/riemann42.jpg[/img]
If it doesn't have a bowtie it's just an imitation.
#139789 07/10/2004 9:22 PM
That's the problem. This truck was bought brand new by the people I'm getting it from. It has never been wrecked either. It is a 133" wheelbase dual tire rear. It's a rice hauler from my cousin's farm. Title and registration says 1942 while the VIN code is 1939. I'm at a lost with it.
#139790 07/12/2004 2:54 PM
Big Bolt Shop Curmudgeon
Great looking old truck. Definitely not a '39.
Go to "The engine and Driveline Shop" and read about Tony's (Truckedup) work on freeing up a stuck engine.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
#139791 07/13/2004 1:29 PM
Before seeing the picture I thought they might have done a retitle. But thats definitly 41 thru early 47 styleing. With my 1938 1 1/2 ton they replaced the engine in 42 and retitled it as a 42. If the truck was used much there is a good possibility the engines not original. My grandfather had a small fleet about 10 trucks mostly stovebolts and it was common to have several engines in the crate around so they could be swapped quickly and the truck back making money if he did it that way it was proably common practice.
Good luck with your project.
#139792 07/24/2004 4:53 AM
Y
Y Offline
You may want to check this site also.... www.haist-usa.com/artdecotrucks/ Lots of good spec, model number, and ID number info there. If memory serves me correctly, all trucks built from 1942 thru 1945 were numbered as 1942 models, which skewed the month/date sequences. Kind of like a 36+ month year numbering system. HTH
