3 members (TexasA&M48Truck, Gdads51, Bucker), 84 guests, and 6 robots.
Topics128,212
Posts1,057,463
Members48,471
When I bought my truck the intake and exhaust manifold were off the head. Can anyone give me a list of the proper bolts and or stud dimensions.
I've also included pictures of a part that I can't remember where it goes. I normally bag and tag all the parts and take lots of pictures as I disassemble but I missed this piece. It's spring steel, approximately 12"x1 1/4" and forms a loop as shown in the pictures. Thanks for the help guys
That's the brush shield for a starter or generator...wraps around the main body to cover the holes to keep the dirt out.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Is that the generator brush inspection port cover?
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Wow, that was quick
Must be off the starter, trucks been converted to a alternator. Thanks Mike B and shop shark I remember now, it was in the glovebox and must have been on the old generator
Do you have the washers.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Yes I have the spreader washers. Just need dimensions for the bolts and studs
How’s this
"The Journey"
Follow in the DITY
Perfect, thank you
Crusing in the Passing Lane
Chevy’s,
When installing the manifolds, if they have been apart, it is best to snug up the inter manifold bolts, but not tighten them ‘til both manifolds have been attached firmly to the head.
Ed
Curmudgeon
Curmudgeon
Put a straightedge against the manifolds to check for level.
Assemble parts loose. Shake it a bit to make parts line up. Slowly finger tighten.
Torque when everything looks good.
Don't forget the alignment rings.
Did somebody quit making tape measures, rulers, machinists' scales, and dial calipers with depth gauges?
Chevys till Id Did you know you can grind the alignment rings flush on the 235 intake then it will bolt right-up on the earlier head that has smaller rings (216} whole assembly fits.
