1 members (Hotrod Lincoln),
126
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 4 Junior Member | | Junior Member Joined: Apr 2004 Posts: 4 | Does anyone know if a 450 series gmc is a 1 1/2 ton or a 2 ton 161 in wheelbase.Also what is the wheelbase of a 49 chevy 3800 1 ton pickup | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Most all of my sources indicate that a 450 series is rated as a 3 Ton Truck. 300 series = 1 1/2 ton, 350 series = 2 ton, 400 series = 2 1/2 ton, 470 series 3 1/2 ton. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | 3800 1-ton will be 137" wheelbase, 60" CA (back of Cab to Axle)
Professional Novice
| | | | | Joined: Apr 2004 Posts: 35 Junior Member | | Junior Member Joined: Apr 2004 Posts: 35 | My '50-4400 has a wheel base of 161" and is 1 1/2 ton. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Hey 4X4gmc, here are some spec.'s that might be of interest. Model: 451-WB(wheelbase) 137in., CA(cab to rear axle) 60in., Model: 452- WB 149in., CA 72in., Model: 453- WB 161in., CA 84in., Model: 454- WB 179in., CA 102in., & Model: 455- WB 197in., CA 120in. | | |
