7 members (Wayne67vert, Otto Skorzeny, Chris's 46 / 515, KEVINSKI, JoergK., WICruiser, Ole49GMC), 97 guests, and 6 robots.
Topics128,172
Posts1,057,109
Members48,463
Page 2 of 2 1 2
Nice installation.
Thinking about these latches for my truck. Are you happy with the fit and operation of the latches?
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
58 3100 Apache Fleetside
Former Workshop Owner
Looking good Steve. thumbs_up What transmission are you installing and are you keeping the original differential and coil spring set up? Also, have you decided what gear ratio you'll use in the rear?
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
They work very well. I would look a little closer and maybe not use the template. Made me cut more than needed but still works well.
1962 Chevy C-10
My Project Journal
I’m using a 4l60E transmission. Keeping the coil rear suspension. I bought some new variable rate coil springs. Replacing the 3:90 gears with 3:38 gears. Not sure I needed to but I will be driving this a lot at some point.
1962 Chevy C-10
My Project Journal
Removing latches.
1962 Chevy C-10
My Project Journal
Firewall repair.
1962 Chevy C-10
My Project Journal
More latch patching.
1962 Chevy C-10
My Project Journal
Mocking up the rear roll pan, might have found a place for some LED taillights...
1962 Chevy C-10
My Project Journal
Back up camera location found and tested. Spray out of the color now to pick the seat leather color...
Camera
1962 Chevy C-10
My Project Journal
Light placement done.
1962 Chevy C-10
My Project Journal
Roll pan work.
1962 Chevy C-10
My Project Journal
Fox Offline
Looking sharp!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Looks great!
Sunday work. Ok
1962 Chevy C-10
My Project Journal
Rails sand blasted and re-welded in place.
1962 Chevy C-10
My Project Journal
Lot’s of chasing thin metal with the welder. I am finally done with the hood welding.
1962 Chevy C-10
My Project Journal
Added some sound deadner prior to welding the lower door skins on. Eaisier on the arm, don’t have to fit it through the tiny access hole. Lol
1962 Chevy C-10
My Project Journal
Electric window regulator checked out and master switch installed in dash.
1962 Chevy C-10
My Project Journal
Time for a new ring and pinion. Changing from a 3.90 to a 3.38 gear.
1962 Chevy C-10
My Project Journal
you changing your axles? Some day I may need to do this. Please keep your shopping list.
~ HB
1962 Chevrolet C10
1962 Suburban
Keeping the same axles.
Had to clean up some poor castings that were left.
1962 Chevy C-10
My Project Journal
Finished the rear end rebuild today!! Had to make a few tools but got it done.
1962 Chevy C-10
My Project Journal
Have been really struggling to figure out how to make electric door locks work. I have figured it out but it will only work with the actuator and with no mechanical way to lock or unlock. Will see how it goes but needed these to work with my security system.
1962 Chevy C-10
My Project Journal
Finally back in the shop. Found some pin holes In the cab corner that was replaced.
1962 Chevy C-10
My Project Journal
Found what is the last bad place on the cab that needs some repair.
1962 Chevy C-10
My Project Journal
Authorized Pest
Authorized Pest
Just moved this thread from the DITY Gallery to the Project Journals. Definitely belongs here.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Wish I could have done that with my rear mount. Nope had to replace the whole thing which was impossible to do with all the welds in that thing.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Now that I see how the door skin comes apart I should have done this. I bought all new doors. Next time I will know better.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
LOL, That's a good idea. I nearly got my arm stuck inside one of my doors. Nearly needed help to get out. big_eek
Page 2 of 2 1 2
Moderated by  Phak1
