2 members (klhansen, 1 invisible), 137 guests, and 3 robots.
Topics128,211
Posts1,057,473
Members48,473
Any recommendations on a proper fit for a 5 or 6 speed manual transmission to go behind my 350 SBC? It's going in my 1951 Chevrolet 3100 on a 1987 S10 frame.
I know of the T5 and the T56, but I'm not sure if there are other or even better choices. (I'm not a transmission guy if you can't tell, but I'm learning!)
colby
1952 Chevrolet 3100: Photos
Engine: 219 L6 to 250 L6 to 350 V8
Transmission: Borg Warner T56: 6 Speed (1994 Firebird)
1955 Chevrolet Bel Air
Engine: 265 V8
Transmission: Three Speed
Currently: Rebuilding Engine & Differential
1956 Chevrolet 6400
Engine: 250 L6
1958 Chevrolet Apache 3600
Currently: In Barn
1963 Chevrolet C10 Fleetside
Currently: In Barn
T5
T56
NV3500
Nissan CD009
Or a saginaw or muncie if you went 4 speed.
Borg warner overdrive makes a 3 speed a 5 speed 👍
4, 5, or 6 speed doesn't really matter- - - - - -that shifter is just a toy to play with. A 350 has a wide enough torque band that anything over 3 speeds with about a 3.30:1 rear end gear is just going to give your right arm and left leg a little more exercise- - - - -AKA "Rowing it with the shift lever"! Buy an automatic transmission and cut the pockets out of your pants!
LOL!
American Powertrain
They have what you are looking for. 5 or 6 Speed, built to handle what ever and they have a 24 hr tech line. Could give them a call and tell them your specs and what you want and they will set you up.
My brother had a T56, 6 Speed with two OD's behind his built 350 bored .060 over and it has held up very well. Only issue he ever had turned out to be the Centerforce clutch. He had towed many a vehicle on his trailer without issues with it.
58' 3200 235 3-speed/OD
Riding in the Passing Lane
The latest issue of Hot Rod Mag. has an article on the different 5-6 speed trans.
George
1972 Chevy c10 Cheyenne Super
Depends on rear end gears, and what you want to use it for
If lots of highway cruising, nice to keep your rpm’s down for fuel consumption and noise
1940 Chevy KC 1/2-Ton
I have American Powertrains aluminum bell housing to mount my TKO 600 on my 292. It's rated the same as steel Quick Time bells.
