8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 1,045 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,045 | I have a glass manufacturer willing to make me acoustic glass for my 53 1/2 ton pickup. This is a favor and not what they normally do. They mass manufacture production windshields. They do not have the patterns for the glass. Does anyone know where I can get the patterns or an electronic file to send them. This is not cheap and I want to get it right. Thank you for any help you can give me. I'm not ready to remove the glass in my truck and don't know if it's original anyway.
| | | | | Joined: May 2005 Posts: 86 'Bolter | | 'Bolter Joined: May 2005 Posts: 86 | Mick Jim Carter sells heavy paper window glass templates for your 53 truck. P/N WI172 $18.50 a set. *includes all windows Hope this helps!
Mike 1951 Chevy 1/2 ton w/ 1959 235 1971 Chevelle
| | | | | Joined: Apr 2016 Posts: 1,045 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,045 | Mick Jim Carter sells heavy paper window glass templates for your 53 truck. P/N WI172 $18.50 a set. *includes all windows Hope this helps! Thanks for the quick reply. I spoke to Jim Carter trucks and his supplier has discontinued the patterns for the 53. He hooked me up with Bobs custom auto glass at 800-624-2130. He said since I'm a veteran he will send them to me for free. He also discounts all steel rubber parts and makes his glass. Complete with tempering over and water jet cutter. Thank you so much for your help. I didn't want to lose this opportunity. Thank you for your time.
