3 members (1955 1 Series, 5 Window 9434, BC59), 137 guests, and 2 robots.
Topics128,087
Posts1,056,107
Members48,434
#1393338 01/19/2021 2:03 AM
I removed the fill spout on my 3600 under bed tank today. I am going to build a new tank and will reuse the spout. I was going to look at the sending unit but there was a baffle in the way. But I found this instead.
1947 3600 Chevy
AD Addict & Tinkerer
Thats quite a find. Got to wonder, what they were doing when they lost that set of pliers!
Phil
Project Journals
Stovebolt Gallery Forum
Maybe original from a truck tool kit .treasure
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1393361 01/19/2021 6:01 AM
Nice find! That sending unit should come right out the top. I removed the original sending unit from my '48 Chevy that was frozen tight but after a few days of soaking with Deep Creep it freed up. Still working a couple of years later even with the original cork float.
Lumbersawyer Bet those are not chinese made!!
fixite7 #1396267 02/07/2021 10:26 PM
I threw them in a can of E85 to clean off the gunk, used a small hand wire brush to clean the rest off. no. 226 MADE IN THE USA . Does anybody recognize them? I also found a double open end wrench laying on the cement that fell after I removed the wood bed in the box. Definitely from back in that time period.
1947 3600 Chevy
Looks like the ones that came in the "took kit"...is there a "V" cast into the handles?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Exactly where on the handles? They are quite worn.
1947 3600 Chevy
Ex Hall Monitor
Ex Hall Monitor
The early OEM tool kit had two tool suppliers, one of which was Vilchek, the other McKaig-Hatch. Vilchek would mark their tools with a V. One easily identifiable Vilchek characteristic is a "swoop" in the handles which yours don't have. I have no idea how long GM used those suppliers.
The V is to the left of the Forged in USA stamp.
Additional info.
Look on the inside of the handle grips...they stamped the knurled grips on the outside and the "V" (if there at all) on the inside all in one press.
They could just be a pair of hardware store cheapies...but they still have a neat story!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
No markings on handle. It is not like the picture in Tony’s post, these are stamped most likely, as the jaws are much thinner than most pliers.
1947 3600 Chevy
