8 members (Otto Skorzeny, Bill Hanlon, Southerntruck, DaveV, TexasA&M48Truck, Peggy M, TUTS 59, 78buckshot), 250 guests, and 8 robots.
Topics128,078
Posts1,056,039
Members48,433
#1396149 02/07/2021 2:05 AM
Hello! Does it matter which direction the unit is facing when replacing the under seat unit? THANKS!
Crusing in the Passing Lane
Just so the float has free movement. Bolt pattern in tank for the assembly might dictate how to face.
Ed
Ex Hall Monitor
Ex Hall Monitor
While the mounting holes appear to be the same distance from each other they are not. There's only one position that it will mount and all the holes line up. As Ed mentioned, point the float toward the area of least interference and you'll probably be right.
Thank You Gentlemen! I was having a panicked blonde/senior moment last night. Bolt pattern and float movement dictate direction. Now off to wiring to make sure its connected properly to the back of the Jim Carter reconditioned fuel gauge in the cluster. Thanks as always!
