1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#139578 10/07/2007 11:20 PM
Guys, Just bought a 83 longbed S10. My question is, dose the AD cab sit further forward or further back compared to the S10 cab on the S10 frame ? The reason I ask is, I'd like to rebuild the AD bed and mount it on the S10 frame with the 4x4 rear axle. I'd to continue driving the truck until I get the body work all done the AD cab and than mount it on the S10 frame. Is this doable or am I going about this *** backwards ? ohwell
#139579 10/08/2007 2:57 AM
Former Workshop Owner
I don't think that there are any simple answers.I suggest that you grab a tape measure, and see for yourself.
In my opinion, you are going to need another vehicle. The type of project that you are starting is a major one. There will be lot's of surprises, that will most likely prohibit you from accomplishing all that needs done (safely) in a short period of time.
I think that it would make the most sense to mount the cab first.
Good luck
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#139580 10/11/2007 1:11 AM
Measure from the front axle Centerline as the S-10 frame will move your rear axle a little as compared to the AD.
