7 members (Thomaslb, 1955 1 Series, Hanks custodian, Ridgeback, Hotrod Lincoln, Ponchogl, 1 invisible),
46
Mod | | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 42 | Guys, Just bought a 83 longbed S10. My question is, dose the AD cab sit further forward or further back compared to the S10 cab on the S10 frame ? The reason I ask is, I'd like to rebuild the AD bed and mount it on the S10 frame with the 4x4 rear axle. I'd to continue driving the truck until I get the body work all done the AD cab and than mount it on the S10 frame. Is this doable or am I going about this *** backwards ?  | | | | | Joined: Nov 2004 Posts: 2,408 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,408 | I don't think that there are any simple answers.I suggest that you grab a tape measure, and see for yourself.
In my opinion, you are going to need another vehicle. The type of project that you are starting is a major one. There will be lot's of surprises, that will most likely prohibit you from accomplishing all that needs done (safely) in a short period of time.
I think that it would make the most sense to mount the cab first.
Good luck
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Measure from the front axle Centerline as the S-10 frame will move your rear axle a little as compared to the AD.
