Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TUTS 59, DennisM, greenie-reddy, KEVINSKI), 151 guests, and 5 robots.
Topics128,283
Posts1,058,515
Members48,490
#139573 10/06/2007 7:14 PM
Since I have my truck apart, I have been toying with the idea of converting to rear disc brakes. I recently installed a Chevy II rear end which will require a brake job anyway. I see brackets for sale all the time on ebay but was wondering has anyone done anything similar? Is there a salvage swap that would do the trick? I'm running a firewall mounted booster/master cylinder, so do I still need to install a proportioning valve & residual pressure valve?
Robert C.
I'm a Genius in the making.
1950 3600
#139574 10/07/2007 5:39 AM
1 Offline
I installed a 1981 Trans am disc brake rear end in mine but Im not sure if there's a salvage yard swap that would work on your Chevy II rear end there's some really cool conversion kits out there. I'm also running a firewall mounted booster/master cylinder on my 51 and yes you will have to get a disc/disc proportioning valve,
Drum Brakes require residual pressure of 10 lbs, The disc/disc setup does not require this pressure. They only require 2 lbs of pressure
But I don't think you'll need to get the residual pressure valves They run in-line and act as a one way check valve and prevent fluid from bleeding back to the master cylinder. They are usually only installed when mounting your master cylinder under the floor
you shouldn't have the problem with fluid bleeding back to the master cylinder on the firewall mounted booster/master cylinder
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
#139575 10/08/2007 2:25 AM
I was under the impression that the proportioning valve had residual pressure built in.
Robert C.
1950 3600
#139576 10/08/2007 2:41 AM
Some master cylinders have the residual pressure valves installed and the proportioning is designed in for the application. A stand-alone proportioning valve would need to be different for disc or drum brakes if the residual valve was integral.
#139577 10/11/2007 1:31 AM
I built my own setup for my S-10 a while back using Camaro calipers, and custom aluminum brackets to rotate the calipers to clear the leaf springs. Have a picture I can email if interested.
I also installed really big disc's on the front with Corvette calipers as I wanted Stop along with the Go.
A multi-position rapid adjust proportioning valve was used so I could add more rear brake bias when I ran loaded compared to empty. (Some Chrysler mini vans and trucks have the proportional valve tied in to the ride height, so when loaded the rear brakes get more pressure sooner.)
