| | | Forums66 Topics128,096 Posts1,056,477 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 5 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 5 | I have a spicer pto that leaks and need to get replace two seals. One of them has legible numbers and the bearing house can get me that seal but the other ones numbers are too hard to read. Is there a source to determine what ptos used what seals? Been to the local pto sales place and they couldn't help along with all the bearing houses and no luck. Thanks in advance. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to the bolt! Do you have the seals out? A good bearing place should be able to measure the seal and look up a replacement by the measurements. | | | | | Joined: Sep 2020 Posts: 5 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 5 | Yup have seals out and I thought the same thing but 4 bearing shops and 1 pto place later and nothing. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 51AZ6500, could you tell us the make of the p.t.o. and give us the seal dimensions please. | | | | | Joined: Sep 2020 Posts: 5 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 5 | The pto shop said it's a 100 series. I have seals at shop and can get dimensions Monday. Was able to match up shifter seal but not shaft seal. Ordered what appeared to be correct seal through o'Reilly's but wasn't. The seal that came in was numbered different from box. Hoping was just a packing error at National. | | |
