4 members (TUTS 59, Lightholder's Dad, klhansen, 1 invisible), 165 guests, and 0 robots.
Topics128,109
Posts1,056,266
Members48,439
#1395443 02/02/2021 5:35 AM
I have a spicer pto that leaks and need to get replace two seals. One of them has legible numbers and the bearing house can get me that seal but the other ones numbers are too hard to read. Is there a source to determine what ptos used what seals? Been to the local pto sales place and they couldn't help along with all the bearing houses and no luck. Thanks in advance.
Big Bolt Forum Moderator
welcome to the bolt! Do you have the seals out? A good bearing place should be able to measure the seal and look up a replacement by the measurements.
Mike
Yup have seals out and I thought the same thing but 4 bearing shops and 1 pto place later and nothing.
3B Offline
Hy 51AZ6500, could you tell us the make of the p.t.o. and give us the seal dimensions please.
The pto shop said it's a 100 series. I have seals at shop and can get dimensions Monday. Was able to match up shifter seal but not shaft seal. Ordered what appeared to be correct seal through o'Reilly's but wasn't. The seal that came in was numbered different from box. Hoping was just a packing error at National.
