| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13949 04/20/2004 8:09 PM | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | Gentlemen,
When installing my latest 1954 235 engine in my '53 truck, I opted for a modern-style remote oil filter unit that uses a spin-on type filter. My oil pressure pegs out the 30 lb. gauge at idle, but decreases to the 15-20 lb. range at higher rpm. I know the engine is the "high pressure" 235 and this seems like too low an oil pressure. I know that the "full flow" oil filter decreases oil pressure. What are some acceptable guidelines? Thanks for the advice.
Regards, Tyler Watts | | |
#13950 04/20/2004 8:54 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Did you put a restrictor on the oil filter to keep the flow down? You need one. Since the filter is a bypass filter it will starve the engine for oil if the filter flows too much.
30psi is an acceptable oil pressure for a 235. The pressure should never drop at higher RPM.
#13951 04/21/2004 1:58 AM | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | Mr. Bartlett,
Thanks for the advice. Where can I obtain said restrictor and what will it cost me? I have also heard that a larger filter will mitigate the drop in oil pressure. Would that alone be a sufficient solution?
