7 members (Goach2, Donf, Rusted Nut, Bill Hanlon, JW51, BC59, 1 invisible),
61
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 172 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 172 | I have a 1950 chev truck 3100 with a 1956 open drive differential with a 3.90. ratio with a 9.375 diameter gear. I am doing a full restoration and I am committed already to a 261 engine a T5 transmission from a 1985 s10 with a .76 OD. I was thinking the 3.90 and the .76 with my 16 inch tires would be a reasonable daily driver . However I took the differential into a specialty shop for a service and was told that the gear set was "severely worn " and that chances of finding another set in good condition would be difficult to say the least. I know I could switch the differential out but I also already have the correct axle conversion kit, rim and tires for the six lug so I am still thinking the path of least resistance is to track down a 3.90. I tried on line Tom's Drive line but they list in a older catalog only the 3.38 which would not work well with the T5 . I have tried other online sites and no luck. I have a phone call out for used ones but of course no guarantees he used one would be any better that what I have. Any suggestions as to locating a 3.90 or other thoughts would be appreciated
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Im running a 65-66 Chev rear axle under my '46 (had to keep artillery rims), this diff is 3:08 ratio and is just fine with my T-5 and it's low gear in first. A bit high geared but was a gift and I like it just fine. I'd jump on the 3.38! Best of luck | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I have a nos 3:90 ring and pinion gear set, if your interested send me a PM and we can chat.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Aug 2019 Posts: 172 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 172 | Thanks Phillip I thought I replied already but I don’t see it so just in case I am resending . That is fantastic you have a nos 3.90 pinion gear. What are you asking for it?
Rick | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | No buying or selling in the garage forum. Take this to PMs please.
