5 members (3B, DennisM, 52hornsby, Gdads51, dt235sd), 81 guests, and 0 robots.
Topics128,049
Posts1,055,693
#1394802 01/28/2021 11:15 PM
Not exactly sure what engine I have can someone help me decipher the numbers
Head on drivers side 8836848. Gm29
Passenger side B58848850
Block on passenger side fo5295 on small angle
Right above starter e282
Just above fuel pump. 8769716
Please help if you can. I’m new to the site. And I have tried to decipher it but no luck
also this is in a 1950 but i was told by the previous owner it was not original but should be what came out of it so if i could find out if it is a 235 and the year i can order some parts that i need
8769716 = 1958-62 235 Block
E 28 2 = May 28, 1962 casting date
F05295 is the stamped engine code.
F = Flint Engine Plant
05 = Month (May)
29 = Day
5 = Revisit this number, it should be a letter (A, B, J, ???)
Your engine was assembles one day after it was cast!
Casting number 8836848 is a 235 Head used from 1956-62.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thank you very much. I will check out that last number or letter.
