| | | Forums66 Topics128,026 Posts1,055,400 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13940 02/09/2005 3:27 AM | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | My truck has never had the heat riser spring and I can't figure out where exactly it installs. There's freedom of movement on the riser, as turning it with my hand is a snap (I understand these things stick quite regularly).
If anybody has a picture they could post regarding the spring, I'd greatly appreciate it. I'm assuming it doesn't install internally, meaning within the exhaust manifold. Thanks in advance for your help!! | | |
#13941 02/09/2005 3:41 AM | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | I don't have a picture handy, but the spring does go on the outside of the heat riser. The shaft should have a slot on one side and a pin on the side of the riser. The center of the spring goes in the slot and the outside of the spring will have a curl or a loop to fit on the pin. You may have to wind the spring a tad to get it to stay snug on the pin. Don't wind it too tight (that is an extra turn after it already has tension. If the pin has rusted off, you may be able to drill a small hole and use a roll pin, but if there is a lot of play on the shaft, you may have to replace the valve. Hope this helps.
Truck Tinker | | |
#13942 02/09/2005 4:50 AM | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | Starsfan, Counterweight sould be horizontal when cold. When viewed from the front of the truck the shaft is rotated clockwise when cold, then rotates CCW as spring heats up In the 57 manual it says the spring should only be turned 1/2 turn from where it rests when it's not hooked on. Hope this helps.......
