| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | I replaced the 1-2 shift fork and now tranny won't shift into 4th gear. Shifts smoothly in all other gears. It feels like it's partially going into 4th just not all the way. I replaced the shift fork shaft detent springs and ball bearings so I know the forks are moving smoothly. I also replaced the shift lever and alignment pins so the lever has no slop. I've tried turning the input shaft as I'm shifting with no luck. I'm at a loss guys. It's a muncie sm420
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Posting the same question in multiple forums is not within Stovebolt rules.
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Could one of the detent balls have rolled out into the shift rail channel keeping the rail rod from traveling all the way? If everything was working before you took the tower off, you need to take it off again and retrace your steps. Mike B  | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | Could one of the detent balls have rolled out into the shift rail channel keeping the rail rod from traveling all the way? If everything was working before you took the tower off, you need to take it off again and retrace your steps. Mike B  When you get the top off make sure you can more the 3 -4 syncro into 4th. Rule out that go back over the cover. Do you have a service manual?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | Yes, it was shifting fine before I rebuilt it. A detent ball out of place is a possibility. The only other thing I can think of is the synchronizer isn't seated properly. I have a service manual that I refer to on a regular basis. This is the first transmission I've rebuilt. I'm using the Novac rebuild kit which has better instructions than the service manual. Everything was sliding and rotating in the case before I put the top on so I'm pretty sure the problem is in the shift tower but anything is possible. Thanks for the help guys. | | |
