3 members (Pete1946, 5 Window 9434, baldeagle), 104 guests, and 2 robots.
Topics128,094
Posts1,056,064
Members48,433
#1393996 01/24/2021 5:05 AM
While I search for my new shift knob, my next issue is putting my hydraulic PTO pump on. Does anyone know what kind of gear I need for a sm 420? I was hoping to get lucky and the one would work off the truck I got my picker from, but it was a newer ford so I couldn't be so lucky, I have the helical cut gear on my countershaft if that helps
From what I can find, if it helps anyone else,. Is I need a 33 tooth drive with a left cut. Now I can at least call a gear shop and price one out
Border Mechanical Used to struggle with that left cut/right cut need gaskets for shims gotta rattle for clearance on winch 2 speeds takes some doing but once the Tulsa gets power your ready for big fun !Always liked to take the winch truck out !!
No winching for me, mines to run my picker and air compressor, not ruling out. A winch in the future as I do have a farmer tow truck boom that can be dropped on if I feel like it
Crusing in the Passing Lane
There are books that tell which PTO goes with which gearbox, but they are few and far between plus the numbers on them are easily damaged so no info is available. I have two from 420’s, don’t know the numbers, though.
Whenever removing a PTO I always stamp what box it came off.
Ed
3B Offline
Hy BorderMechanical, please check your private messages.
I have one that came off of a 63 GMC with a sm420. Looks like da # is GNG7H. Look at pic.
