| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 49 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 49 | I have 51 3100 on a S-10 chassis. Does anybody know if I can safely put a BB chevy motor in it using the stock SIO front suspension? Also, I want to put a large set of tires under the rear. Any recomendations on rear end/wheel combinations? Thanks in advance for your recommendations. Jeff | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | As Joe says, the BB in the S-10 should not be a problem. What transmission are you going to run and how do you plan to drive this thing?
I assume going to an S-10 frame you aren't building a monster trailer puller or a car hauler so you don't need to consider things like a 14 bolt or bigger rear. If you plan to work a 502 or bigger motor, or even if you plan to push a 396 hard, you'll want a stout rear.
If you are just putting the big motor in for eye appeal, a 10-bolt GM rear should be fine. Otherwise you probably want a 9-inch Ford. There are other options, but I can't come up with any real good reasons for something obscure without knowing more about your intended use.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2007 Posts: 49 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 49 | Probably a warmed over 402-454 with a turbo 400 trans. I want soemthing that will perform as well as look good. I have always liked AD's with a big set of rear tires-now I want to build one. I plan to "drive" it. I may go for a blown small block. At this point I am trying to get as much input from the guys that have built one and can save me from going down the wrong path in construction. Thanks,Jeff | | |
