5 members (jmoore, dt235sd, 46 Texaco, cmayna, TUTS 59), 66 guests, and 3 robots.
Topics128,203
Posts1,057,412
Members48,471
Hi All
I have canadian Maple leaf right hand drive 47 Truck.
From the ID plate -attached.
IModel is: 11NZ840
serial#: 7-1133- 31547
From this I get:
7 - 1947
1 - Chev
1 - 1100 or 9100
3 - 137 wheelbase
3 - cab chassis
My question. What is the difference between an 1100 and 9100 and how would I know which it is?
I plan to turn it into a daily hauler.
Thanks in advance for any help.
Danny Sunkel
Beginner 2 tonner at Large
3B Offline
Hy DannySunkel, Welcome, the numbers on your identification plate have arrived there by two different methods, the "serial" number has been embossed into the plate, most likely in Canada before the truck was exported, the balance of the numbers have been stamped into the plate, most likely to conform to New Zealand identification standards. In Canada your serial number would decode as a 1947 Chevrolet 1 1/2 ton cab and chassis truck with a 137" wheelbase. If your front axle has a screw in eight sided cap that would confirm it. Maple leaf trucks were 2 1/2ton identified as a 16 series and 3ton identified as a 17 series, the 3 tons were powered by GMC engines, hope that helps.
2 Offline
1100 is the Chevy
9100 is the gmc
The two share most parts with exception of anything gmc branded.
I am curious if you have a metric speedometer cluster in your truck
Please post a photo of your dash if you can
-s
Thanks for the info. I will get Pic of the dash for you next time I'm at the storage yard.
Canada didn’t switch over to Metric system until around 1975
1940 Chevy KC 1/2-Ton
2 Offline
GM produced metric speedos for export to countries that were metric
When Canada switched to metric is not relevant to the exported vehicle, the target countries laws regarding imported vehicle compliance is the issue.
To date I have only seen 1 example of the metric version of each the 0-80 mph and the 0-90 mph Speedo
I own one of them that came from South America
Even the odometer counts in in KM not miles
I would like to collect more information about metric specific parts for my own interests
-s
Took a pic of the dash cluster. just trying to work out how to post it.
Moderated
Moderated
Im a bit late to the party on this one, but the one picked up in november has a very simmilar number,
Model 11NZ840
Serial 7-1133-31451
I have been trying to get info from NZTA but its been out of the system too long. your post has helped work it out.
Moderated by  Gord&Fran
