3 members (carbking, DaveV, 1 invisible),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,427 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 14 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 14 | 1950 3600. Got the truck back from having all new brake lines put on. First time I've been able to drive the truck at any speed and definitely first time in fourth gear. When it got there, the clutch started slipping. Bad. I wasn't going to dog it but I didn't feel any slipping in gears 1-3. Any suggestions. Place to start? Cheers!
Ben
| | | | | Joined: Feb 2019 Posts: 4,483 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,483 | I assume this is a 1950 3600? Do you have any free play in the clutch pedal? You should have 3/4” to 1” free travel before the clutch starts to disengage.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you do have free play in the clutch pedal, then you need a new clutch, if not, adjust it properly. Clutches always start slipping in higher gears since more torque is required in a higher gear.
Easy to do.
Ed
| | | | | Joined: Dec 2020 Posts: 14 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 14 | The clutch pedal itself is very mushy. Is that typical? | | | | | Joined: Feb 2019 Posts: 4,483 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,483 | The clutch pedal in my 3100 is not hard to push but I would not say mushy. You didn’t answer my question. Do you have free play in the pedal? That must be answered before we can go further.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Test for free play with your thumb. Your foot can't detect it very accurately.
| | | | | Joined: Dec 2020 Posts: 14 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 14 | My fault. 1950 3600. I’ll have to check for true free play. Truck is at my dads garage. I’ll check tomorrow and report back. | | |
