1 members (RLB),
83
Mod | | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | I'd like to upgrade the rear suspension on my 1942 3/4 ton. I've looked at a lot of options for this, but have not found a supplier that makes a kit which is specifically for the 41-46 3/4 ton. Does anyone have any experience with updating suspension in the Art Deco series of 3/4 ton trucks? I want to keep my OE Artillery wheels and the stock 6 lug bolt pattern. Also, has anyone converted to 6 lug rear disc brakes, and retained the OE Artillery wheels? Thanks for any advice you may have.
Ghost Rider Little Egg Harbor, NJ 1942 Chevy 3/4 ton pickup, 1962 235, Offy intake, Fenton headers, Dual Carter YFs, 1984 T5 1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One can replace the rear axle with a 14 bolt, sf axle, 6 lug, check the width. TSM makes a disc brake kit, uses Eldo calipers.
Ed
