6 members (Guitplayer, Gdads51, Gray_Ghost, sron48, MRMEROTH11, 1 invisible), 89 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#1393736 01/22/2021 11:25 AM
Hi all, My king pins are froze solid on my 51 3804 and I was wondering if I could swop out the whole axel from the same year 3600? Thanks in advance. Gerry
51 3804 #1393739 01/22/2021 1:34 PM
Crusing in the Passing Lane
Are the retainer keys removed? Gentle heat should help.
ED
51 3804 #1393760 01/22/2021 5:01 PM
The 3600 uses slightly narrower leaf springs, so the u-bolt holes would need wallowed out. The alignment hole for the leaf springs may need to be redrilled too.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
51 3804 #1393773 01/22/2021 7:06 PM
2 Offline
1.5 inch vs 2 inch wide leaf
If borrowing the axle bring the narrower leaves with it
Then you only need spacers for the leaf connections
And maybe a custom bolt and sleeve at the rear leaf connection points
-s
51 3804 #1393833 01/23/2021 2:48 AM
Is that a single, double, or triple axel? Only your friendly local figure skater knows for sure!
2ManyTrucks #1393943 01/23/2021 9:51 PM
-s
The 3800 springs are not only wider, but they are longer too. Not to mention, the shackle pins are tapered and specific for the 3800 and the 3100/3600 front springs. Not to mention there is differences in the frame dimensions also, so even if someone would want to use the 3100/3600 spring hangers, it still may not be possible.
"The Fake Truck"
Hotrod Lincoln #1393960 01/24/2021 12:44 AM
62401
Jerry ... nono Obey your mother -- Be nice! Follow Ed's example nanner
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
51 3804 #1393989 01/24/2021 3:44 AM
You guys disappoint me. Jerry is referring to the proper choice of "axel vs axle". Axle is a shaft wheels rotate on and axel is a jump in figure skating. Jerry wins this one.
Evan
51 3804 #1394105 01/24/2021 9:48 PM
I knew what he was getting at, I just chose to ignore it. Since when does Jerry not have an opinion? LOL
I frequently send texts, emails, and post on forums with the wrong homonym on a regular basis, thanks to the autocorrect function on our modern devices.
"The Fake Truck"
