6 members (Tronman, wilbur53, Jon G, GMCJammer51, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,109
Posts1,056,569
Members48,448
I have a 51 3100 that sits on a S10 chassis. Can I safely put a BB chevy engine in this chassis. Is the stock front end strong enough?
I would like to put a large set of tires on the rear-what is the recommendations for a rear and wheel combination?
Jeff
Might consider putting some beefier springs in the front, perhaps a set for a Malibu station wagon. Out back, you'll want to put a stronger diff in. the S10 used the small 10 bolt, not really all that strong. Especially with a big block and larger tires. To keep it easy, try for a 10 bolt from a later ZR-2 truck. They use a narrowed full size 1/2 ton diff that's much stronger, plus the later ones have factory disk brakes.
For tire size, a 31x10.50 is about a big as you can go with the stock ride hight and fenders, anything bigger will rub. Being that it's already on an S truck chassis, probably would be around a 28" tire max diameter.
Bill Burmeister
I would box the frame reinforce with crossmembers where possible and upgrade to IFS. Better safe than sorry. My 2 cents given what little information you have given here.
~Jim
Uhh, hey Big Chevy 3600, it's on an S 10 chassis, already IFS grin , but yes, boxing would be a good idea, too.
Bill Burmeister
Thanks guys. What about a 4 link rear? Any experience with installing one of those in the S10?
Bill:
The only thing I know about S 10s are that their bench seat will fit my 51. ohwell
~Jim
Quote
I think they are more narrow. 49" to 50" versus
about 54" for the AD seat if I remember correctly.
Steve
'49 3800
'52 3600
'57 3100
Unlike cars pickups were designed to haul a 1000 or 1500 pound load so the 200 pound increase in engine weight isn't anything they can't handle. Frame and chassis are also able to handle the increase but the stronger rear with big horses and tires is good advice. If your not going to use the big block AND run them fully loaded then your within their design specs.
Evan
