0 members (),
93
Mod | | | Forums66 Topics128,096 Posts1,056,488 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 5 New Guy | | New Guy Joined: Jan 2021 Posts: 5 | Good Morning from Suburban Chicagoland!
I am new to Stovebolt and I am blown away by the sheer amount of information, knowledge, and experience on this forum and general site.
I've done a fair amount of browsing around but there's just so much to sift through; I might have missed what I'm looking for.
I am going to check out a rough 1948 3800 soon and was looking for a "buyers guide" or a list of items specific to that year and possibly model to be on the look out for. Each of the beauties showcased on this site have their own congenital flaws and I was just looking for a laundry list of inspection points.
I would appreciate any and all advice related to purchasing my first truck!
I thank you all in advance! | | | | | Joined: Dec 2002 Posts: 3,444 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,444 | Welcome to the 'bolt. regardless of what you end up with I'm sure you will enjoy working on it.
You might want to make a post in the General Truck Talk forum, as there are a lot more folks there than here.
Good Luck
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Welcome to the Stovebolt madness. There is no cure!  Brake drums are non-existent for the 3800. Body parts interchange with the 1/2 & 3/4 tons. Be sure to post your specific questions in the appropriate garage forum. We do have a special forum for the 1 tons.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes : most "Body parts interchange with the 1/2 & 3/4 tons"
But, there may be a few differences: - bumpers and bumper brackets ? - running board lengths ? | | | | | Joined: Dec 2008 Posts: 53 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 53 | When you say "rough", I think of my 1950 3100 and how it had a fresh paint job over very rusted out front cab supports and corners. This caused the hood to be out of alignment and not able to close. I was not skilled enough to fix this and as a result it took me 28 years so far to get this truck done and driveable. I hope you are more skilled than I and will be able to get yours back on the road. But do check the cab corners front and rear at the bottoms and also the cab supports as these are critical for strength and alignment. This will be the year for me!!
Jerry | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Buying mechanical parts for a 3800 is a a bit more effort Most online places don’t list 1 ton compatibility even if it’s the correct part they just don’t know so they can’t help you With exception of those rear brake drums there is a way to get all the standard parts for your 3800, if you are having difficulty finding something just ask the forum  It will be fun, you should def get a 1 ton -s | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | One thing to consider is the "completeness" of the project truck. Try to buy something that isn't missing too many parts. As finding and buying replacements of missing equipment can get pricey in a hurry! John 1949 gmc 1-ton | | | | | Joined: Jan 2021 Posts: 5 New Guy | | New Guy Joined: Jan 2021 Posts: 5 | Thanks for the advice! I'll crosspost this over there. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Note to all: OP has started this topic in GTT. Continue to post your welcomes here but answer his questions in the GTT post. Thank you.
| | | | | Joined: Nov 2004 Posts: 2,418 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,418 | Hello Dan,
Welcome to the "Bolt".
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2020 Posts: 49 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 49 | Good Morning from Suburban Chicagoland!
I thank you all in advance! NADA says low retail is $11,200, Average $26,500, High $69,100. Something to start from.
Ask a question if you need a answer! Resting up on Mon-Fri from Sat and Sun.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Regarding you Huck Brakes, I just got through some work on mine. I replaced the rear wheel cylinders and one of the adjuster wheels. I also dismantled and cleaned out the front cylinders. When I originally got this truck, I had a miserable time getting the drums off, everything was frozen. I had to use a wheel puller to get them off. I have also come to the conclusion that the number of people that know anything about drum brakes is dwindling. lot of blank stares out there.
As far as inspecting, see if the engine spins, 6 or 12 volt, check for oil in the radiator water, condition of the wire harness, see if the heat riser is free, smell the gas to see if it has turned into shellac, condition of the tires, condition of the bed and look for the results from a visit by the good idea fairy.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
