8 members (Gib70, 52Carl, Otto Skorzeny, Rusty Heaps, joe apple, 55shaker, Gray_Ghost, Hush), 147 guests, and 0 robots.
Topics128,108
Posts1,056,238
Members48,437
#1393602 01/21/2021 12:58 PM
Have a gasket leak some where in my exhaust system. Replaced the the doughnut gasket on my ol 6 banger and is still leaking somewhere.. Speaking of what is the actuall size of that there gasket anyway, parts guy said there were 2 of them, the one I bought was 2".Don't see any holes in the pipe new air cleaner, funny thing about it, she runs real good?????????
ol' 55 #1393606 01/21/2021 1:35 PM
Year, model, engine size etc with every question please.
ol' 55 #1393611 01/21/2021 2:24 PM
1955' 3100 1/2 ton, 235 6 cylinder....
ol' 55 #1393613 01/21/2021 2:53 PM
Curmudgeon
Curmudgeon
Try tightening-up on the exhaust manifold bolts to see if they are loose.
As I get older and my hearing gets worse, it's harder to tell which direction a problem noise is coming from.
E-brakes on. Jack up the truck, use jack stands. Transmission in neutral and start engine. Crawl underneath and listen. See if it's louder underneath.
If not there, start over again. Moving your head as you listen can help.
Get someone else to listen preferable one with younger ears than mine.
If you still can't figure it out, very slowly pour something like Marvel Mystery Oil down the carburetor of your running engine.
See if there is smoke leaking out other than the tailpipe.
