1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Hi Guys and Gals, Just got my TCI Must 2 ifs, however was wondering are there any diagrams or photos of steering hook-ups. Should I stay stock and changes required or go w/ something different. I was not told how nor what items I have to purchase to get my wheels connected to that large round thing you hold onto when yer drivin'. I'm going w/manual steering. Thanx in advance for any tips photos or drawings. Going for a surf I'll check back later!
Try prayer as the first response rather than a last resort ...
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Would help to know what year and model your putting it in.
Evan
| | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Sometimes guessing doesn't work, Sorry it's a 54 3100.
| | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | Here is a picture of how I did mine with a modified stock column: http://i24.photobucket.com/albums/c13/rsg2506/IMG_0004.jpg * I removed the steering box from the column and put a new bearing at the end of the column ( http://www.classicparts.com/prodinfo.asp?number=76-987). * I then lowered where the column comes through the firewall about 2 inches and used two steering joints to connect from the column to the MII steering rack. * I made two 3/4 inch spacers to lower the column from the dash to get a comfortable steering angle for the wheel. Hope that helps... -Rich | | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Thanx Rich. This will definetly help. Jack
