1 members (1955 1 Series),
131
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | does anybody know what gas tank would fit in between the rear frame rails,on my 41 1/2 ton.Need all the help i can get. Perro
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I used a long narrow tank from a maybe late 80s chevy pickup. Mounted it on the passenger side frame rail just behind the battery. difficult part is fabing up the filler. I'd just take your measurements and head to pick n pull. I've since gone back to the stock tank under the seat, but you can make other tanks work. | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | Take your measurements and go to a muffler shop. Take the old neck with you. The muffler shop can bend you a new filler neck and weld the fuel cap end on to the new pipe.
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | There are what they call universal tanks on the market that fit in the rear of the Art Decos. I believe theres even one that will bolt up to the bed on the market. If you do a search under this site I believe theres lots of info on this. Good luck as I'm putting one in my 46. Bob T | | |
